90+ valve guides
Started by tck, 04 Feb 2021 at 16:27
tck
On my crossbreed MK4 one of the 90+ heads had a cracked exhaust guide it is being replaced by an engineering firm it looks as it the standard guide 35537 can be modified to fit bit I note that the cracked guide has a small vertical slot in the protruding head of the guide I cannot see what that was for any ideas?
Neville Heath
There is an oil feed slot milled down Plus guides that feeds a radial hole to lubricate the valve stem.
Neville
tck
You are right the path in the head was blocked with carbon it does not seem a particularly effective idea perhaps for racing with lots of stripdowns?
Neville Heath
Everyone I have ever come across has been blocked with carbon. As you say O.K. for one race probably. I still clean them out though!
Neville
Neville Heath
Photo of Plus guide. Note seat is also tapered, not flat like Mark.
Neville
