Clutch thrust bearing ew
Started by john b, 11 Jan 2026 at 11:52
john b
Hi can anybody help wanted clutch thrust bearing does anyone have a used or new
Or have any part numbers or bearing numbers
For 1926/7 ew Douglas
Regards Johnb
It is not a commercial bearing, Douglas manufactured them in house.
Many folk substitute a plain thrust bearing made out of oil impregnated sintered bronze (Oilite). Advantageous if the surfaces the original bearing balls ran against are pitted and provides a bit of braking effect if the clutch has a tendency to drag on release.
john b
Hi Doug thanks for the reply
Regards John
alan reid
Hi Yes, Simply bearings sell a needle thrust race that will fit straight in.
Regards Alan.
john b
Hi  alan you wouldn't have a bearing number by any chance but thanks for the information
Regards John
alan reid
Yes,  the S6 size is 60 X 85 X 5 needle roller
  and the EW I think is 50 X 70 X 5 but both bearings are thinner than the original and
will need a thicker backing washer.
the needle bearing ref is AXK6085ASand AXK5070AS
Any doubts give me a ring 01342-834133 Alan
john b
Hi Alan that is great will get on with this tomorrow thanks again
Regards John
