Author Topic: Piston identification  (Read 2690 times)
Offline Sgtbiro
« on: 22 Mar 2018 at 16:06 »
Hi
I have just found two pistons in a old box of Dragonfly parts that am going through,they are stamped on the top with the number (20647)
but in my parts book it says that the part number for Dragonfly pistons is (34193) can anyone tell me if these are the correct pistons, i also found what looks like a brand new piston but has no number stamped on it is just stamped STD on the top.
Cheers Kevin..
Re: Piston identification
« Reply #1 on: 22 Mar 2018 at 16:58 »
Kevin,
          As you say, Dragonfly pistons (bare) have the part number 34193. Mark 3 - 5 pistons are numbered 37537. T35 Mk1 pistons 33085. Pistons with just the size stamped on the top are probably from the batches of repro pistons the LDMCC have had made over the years. If you post photos of the pistons you have, I will attempt to identify them more precisely.
Offline OCTypeCanada
Offline Sgtbiro
« Reply #3 on: 22 Mar 2018 at 17:53 »
Yer just the same as the one in the link.
Cheers kevin.
« Reply #4 on: 22 Mar 2018 at 17:56 »
That piston is probably for a Douglas generator engine (scarf joint piston rings) but is incorrectly listed as being 60.1mm - it should be 60.8mm.
Offline Sgtbiro
« Reply #5 on: 22 Mar 2018 at 17:59 »
Cheers Eddie so no good for my dragonfly then.
« Reply #6 on: 22 Mar 2018 at 18:11 »
No, I'm afraid not! The generator engine and T35 Mk1 had different shaped cylinder heads to the later models - hence the higher crown on the early pistons.
