Author Topic: Mystery Douglas Part  (Read 359 times)
Offline A31ndrew
« on: 17 Sep 2023 at 19:57 »
This appears to be part of an inlet manifold assembly, although I do not know from which model. Hole centres at the flange are 1.83" and the O/D of the plated stub is 1.1/8". There are traces of solder on the stub where, I presume, it was soldered into a manifold block. Overall condition is rusty but useable. More dimensions available if needed.
Re: Mystery Douglas Part
« Reply #1 on: 18 Sep 2023 at 07:00 »
Looks like an inlet manifold for a DT5/6 ( the carbs were soldered to the manifold!).
Offline A31ndrew
« Reply #2 on: 18 Sep 2023 at 07:04 »
Thanks, Eddie. Free to a good home, if anyone has a use for it.
Andrew
Offline Cliffy73
« Reply #3 on: 18 Sep 2023 at 17:43 »
Hi is this still available?
Offline A31ndrew
« Reply #4 on: 19 Sep 2023 at 09:59 »
Hi Cliff - it is, I've sent you a private message.
