Author Topic: busted clutch bearing  (Read 325 times)
Offline tck
    • old racer
« on: 01 Sep 2023 at 13:17 »
This looks like a difficult part to replace  or make since my clutch does not engage I guess it is the bearing that it pushes against
 this is all I have found so far  :wink:It is from my 1926 350 EW. Is it a part that is common to many models? is there a work around? does any one have one?
Offline Hamwic
Re: busted clutch bearing
« Reply #1 on: 01 Sep 2023 at 20:55 »
Hi TCK,
I've used this needle roller thrust bearing from Simply Bearings on my M32, so search for this and see if it's the business.
NTA2840 Needle Roller Cage Thrust Assembly with 2 TRA2840 Washers 1.75x2.5x0.1406 inch. Other sizes are available.
I needed to make up a bit of space, and found that, of all things, digger bucket shims come in different thicknesses, so with a selection of those a solution can be made up.
Cheers for now
Offline tck
    • old racer
« Reply #2 on: 02 Sep 2023 at 09:27 »
Thanks Doug I will investigate
I must say turning a ring seemed doable but the thought of drilling all those radial holes......:-)
Offline Ken Rogers
  • 1926 EW350
« Reply #3 on: 05 Sep 2023 at 11:56 »
Hi I replaced mine with an oilite washer which I bought from   getyourbearings.co.uk/oilite-washer/aw234002.html
