Worth saving. 1914 cases are much sought after in the UK because to be eligible for the Pioneer Run a bike has to be strictly pre-1915.
The ZA2 Bosch is interesting. It's the correct mag for a Douglas before and a bit after the beginning of the war, but being of German manufacture they were quickly replaced by a range of British magnetos. I don't know much about the ZA2 Bosch Made in USA, but later there were magnetos branded "American Bosch" and "Robert Bosch" made there, so presumably there was a plant in the US active by around 1914. There are dating lists of Bosch serial numbers, but I don't know if the serial number on a US-made magneto will fit in. The water-proof Z magnetos were new for 1912, and ran into the 1920s with not many changes.
By the way "ZA2" is decoded as "Z" (used on most magnetos from the beginning), A=35mm spindle height (vs E=45mm spindle height) and 2=180 degree firing (vs 1=single and V=v-twin). In the British standard, the mag would be labelled "M2".
