Author Topic: 1947 T35 Mk 1 Dynamo  (Read 328 times)
Offline Somerset Man
« on: 25 Apr 2023 at 18:41 »
Which is the correct or can be used Lucas dynamo for this  ? Was told it may be the Lucas E3HM-LO 6V Clockwise - is that correct ?
Many thanks.
Offline douglas1947
Re: 1947 T35 Mk 1 Dynamo
« Reply #1 on: 26 Apr 2023 at 06:10 »
The MK1 is orginal fitted with the "short" dynamo E3HM-LO 6V, you have written. But it has to drive anticlock, because the magneto runs clock wise (looking from drive side).
You can change the drive direction on the dynamo by changing the brushes. To test the drive direction you can "motoring" the dynamo
by connecting D+F and connect 6V + and put - on earth (for Negativ earth on bike).
