2024-06-11, 20:02:05
2024-06-08, 18:30:04
For Sale
2024-06-07, 02:13:36
2024-06-03, 08:23:05
For Sale
2024-06-02, 08:34:05
Parts avalable
2024-06-01, 18:33:27
2024-05-28, 00:09:46
Welcome to the new site!
lucas dynamo
Started by Laurie, 28 Mar 2023 at 09:56
Laurie
Just refurbished E3M. New field coil and armature. Polarised correctly and motors smoothly in right direction. But no output when fun by  my lathe. I recall seeing the fix for this but I can't remember. Do I have to swap the field coil connections or the brushes?.  I seem to remember the brush swap changes direction?
Red
#1
I don't have the answer but the attached may help?
Roy
Image added - Dave, 29Mar2023
Laurie
Thanks. A dim memory  came to me today! Reversing field coil connection reverses rotation BUT if the field coil block has no residual magnetism, a perfectly restored dynamo will not produce electricity unless the field coil is energised at start-up of the test run - in the lathe for example. Once running it will self energise and generate electricity. Stop the test, remove battery and restart - there will be enough residual magnetism to self energise the dynamo.
