Author Topic: Steering damper for OC600  (Read 5068 times)
« on: 21 Oct 2005 at 06:11 »
I know this is a bit hopeful - but I am looking for the components of the steering damper for my OC600. I have the bottom plate that covers the top steering head bearing but nothing else. This is the damper type that fits under the handlbars. I was sent the attached photo which shows the parts - any help would be GREATLY appreciated !!
Larger view HERE
« Last Edit: 23 Nov 2005 at 00:12 by alwyn »
Offline Daren W Australia
Re: Steering damper for OC600
« Reply #1 on: 21 Oct 2005 at 09:17 »
Hi Ian you are welcome to copy my one if it helps Daren
« Reply #2 on: 23 Oct 2005 at 06:00 »
Ian,
Ditto the one fitted to my F28, can make drawings.
« Reply #3 on: 23 Oct 2005 at 07:21 »
Doug/Daren, thanks guys - I didn't realise it was the same as on the later bikes !! Daren, as you are closer is probably easier if I could grab yours to copy - will give you a call.
