Author Topic: Light Motors "The Fairy" Transfer Decals Needed  (Read 829 times)
Offline Hershey Brant
« on: 13 Jan 2023 at 13:54 »
In need of two tank transfer for Light Motors, "The Fairy" please.
Kind thanks for any assistance.
Brant Mackley
Offline LENBOY
Re: Light Motors "The Fairy" Transfer Decals Needed
« Reply #1 on: 13 Jan 2023 at 15:21 »
Hi
The club list's a  "Fairy" Transfer/Decal,  not sure which type it is but hope this is of help.
Len.
« Reply #2 on: 13 Jan 2023 at 17:56 »
Thank you for your response.  I wrote the London Club earlier this week about these and also to join.  I haven't heard back so I thought I would reach out here.
Online cardan
« Reply #3 on: 13 Jan 2023 at 23:03 »
Hi Brant,
Hope you caught up with the thread here about Fairys: https://www.douglasmotorcycles.net/index.php?topic=6560.0
How about posting a photo or two?
« Reply #4 on: 14 Jan 2023 at 07:14 »
The bike has been posted here before by the previous owner.  I intend to take it a little further by adding the transfers and some pin stripe detail paint.
« Reply #5 on: 14 Jan 2023 at 07:16 »
Right side:
Online cardan
Offline LENBOY
« Reply #7 on: 14 Jan 2023 at 11:01 »
Hi Brant
Great pictures,thanks for posting. With regards to contact with the club you say you wrote to the club, if this was by snail mail our Post Office U/K computer system has been attacked and being held to ransom affecting all postage overseas, receiving or posting abroad. Contact Reg Holmes membership secretary through the club  Webb site should obtain the desired results.
Len.
Online cardan
« Reply #8 on: 15 Jan 2023 at 05:10 »
The LDMCC Fairy transfer says, "LIGHT MOTORS LIMITED, BRISTOL, THE FAIRY". "Light Motors" and "Bristol" didn't appear in print after about January 1907 when the firm moved its base to London. So while the transfer might be appropriate for a Mk 1 Fairy, it would be out of place on a Mk 2 like this one. The "The Fairy" script currently on the tank is probably more appropriate.
« Reply #9 on: 15 Jan 2023 at 08:10 »
Thank you for this information Leon.  I found the below six horsepower machine identified as a 1907; if in fact this is a 1907 model Light was still using a similar transfer decal.  So based on the serial number 105 and being a Mark II engine the transfer should read: Light Motor Limited, & London?  Does an original example of this decal exist any known cycles?
Thank you for your time and assistance,
Brant
Offline Hutch
« Reply #10 on: 15 Jan 2023 at 21:55 »
Hi Brant and Leon,
Maybe no sudden transition between the Bristol and London operations for Light Motors Ltd.? This from the Liverpool Journal of Commerce 11 Feb 1907 (and similar ads on 14th and 16th Feb 1907)
I guess  the decal would have "Bristol" on it for Fairies made there and "London" on it for the later ones - but the difficulty would be how to tell which from which - the engine number might be a clue ??
Edit: I presume Stand 58 was at the 1907 Manchester Motor Show
cheers
Hutch
« Last Edit: 15 Jan 2023 at 22:24 by Hutch »
Online cardan
« Reply #11 on: 16 Jan 2023 at 01:45 »
No idea. This head transfer, in NZ, is probably Fairy Motor Co, London, which is later still.
« Reply #12 on: 16 Jan 2023 at 05:26 »
Thank you to both Hutch and Leon for all the information.  The NZ headbadge transfer is a puzzler.  I can make out a crown at the top and wings at the bottom.  No matter how long I stare at this transfer I still can't make out what the image is in the center.
Online cardan
« Reply #13 on: 16 Jan 2023 at 05:44 »
Its a nudie fairy - her right arm is down, her left arm is raised, and her wings are spread. Proper floaty fairy.
« Reply #14 on: 16 Jan 2023 at 14:13 »
Thanks for that, now I see her, lovely!  It seems to possibly be the same artist/designer and/or transfer maker Sunbeam bicycle was using at that time.
