Author Topic: Clutch ew 350  (Read 331 times)
Offline Skank
Clutch ew 350
« on: 10 Sep 2022 at 11:56 »
Hi, does anyone make a screw for the flywheel? I have it cut, what is the length of the screw? Would someone please measure the height of the top plate of the clutch for me, in the photo. Does anyone make a clutch gearbox, see photo. Thank you very much for your help Ondro
Offline Hutch
Re: Clutch ew 350
« Reply #1 on: 16 Sep 2022 at 07:40 »
Hi Ondro,
Welcome to the forum!
I don't have an EW but I do have a motley collection of flywheel nuts. I measured them from the flange to the end where the grease nipple is. One is a CW, two are possibly EW and another one with the flange completely broken off but not EW.
I hope I have understood your question correctly and this helps you work out if your flywheel nut has been shortened? If not, please ask again and I will try to measure what you need.
Hutch
« Last Edit: 16 Sep 2022 at 08:51 by Hutch »
