Author Topic: Douglas post war engine and gearbox's for sale  (Read 11657 times)
Offline Daren W Australia
« on: 11 Oct 2005 at 07:21 »
Douglas post war engine and gearbox cases mostly incomplete for sale will be selling what’s left to an artist for modern sculpture
Engine case #
T 35 S 1026                AU$100 each
T 35 S 1110                AU$100 each
T 35 S 1251                AU$100 each
T 35 S 1727    with crank cams and timing gears (AU$300)
T 35 S 1993                AU$100 each
T 35 S 4196/3             AU$100 each
T 35 S 4548/3             AU$100 each
T 35 S 8463/4             AU$100 each
T 35 S 8868/4             AU$100 each
5188P   including cams (Police #??)   AU$180 each
Gear box cases including most gears but not complete
Gearbox #
T 35 S 388          AU$100 each
8337                  AU$100 each
B126                  AU$100 each
B150                  AU$100 each
B301                  AU$100 each
B1054                AU$100 each
Please let me know if you are interested as these bits can be put away for delayed pickup I can ship International via Australia Post for all items under 20 Kg and payments in US$ AU$ & Pounds Sterling also via www.paypal.com
Offline trevorp
Re: Douglas post war engine and gearbox's for sale
« Reply #1 on: 19 Oct 2005 at 11:38 »
darren the 5188p what are they are they just cams or cases and cams
Offline KiwiJohn
« Reply #2 on: 20 Oct 2005 at 05:29 »
Daren,  are there any bits in there that I am likely to need when I eventually try to repair my starter ratchet?
Thanks.
« Reply #3 on: 20 Oct 2005 at 08:04 »
I will have a look this weekend Daren
Offline eduardovasquez
« Reply #4 on: 15 Nov 2005 at 17:08 »
Engine case #
Gearbox #
8337                  AU$100 each
B126                  AU$100 each
B150                  AU$100 each
B301                  AU$100 each
B1054                AU$100 each
DARE , THE ENGINE INCLUIDE THE CONRODS, PISTON, CYLINDERS, CRANSHFTS,CRANSHAFT BOB WEIGHT, I AM ASKING BECAUSE I NEED THE ENGINE WITH ALL PARTS, I NEED MAGNETO TOO, LET ME KNOW WHAT PARTS THAT YOU HAVE FOR SALE TO ME.
REGARDS, EDUARDO
« Reply #5 on: 19 Nov 2005 at 00:44 »
Hi all these cases have gone
T 35 S 1026
T 35 S 1110
T 35 S 1251
T 35 S 1993
T 35 S 4196/3
T 35 S 4548/3
T 35 S 8463/4
T 35 S 8868/4
these gearboxes are still available
Gearbox #
8337                  AU$100 each
B126                  AU$100 each
B150                  AU$100 each
B301                  AU$100 each
B1054                AU$100 each
I don't have any complete engines or mk barrels.
There are some t35 barrels left
Regards Daren
Offline KiwiJohn
« Reply #6 on: 19 Nov 2005 at 05:28 »
Hi Daren, have any of those boxes got starter mechanisms?
Offline trevorp
« Reply #7 on: 19 Nov 2005 at 07:51 »
darren if u have 2 reasonable t35 barrells email me with price and postage to melbourne 3013
« Reply #8 on: 19 Nov 2005 at 08:05 »
Hi John there are several with the kick start mechanisms which bit do you need send a pick if you can or the part # and I will have a look for you will be in the garage playing tommorow Regards Daren
« Reply #9 on: 19 Nov 2005 at 08:07 »
Hi trevor let me know the bore size you need Regards Daren or call me on 0413 02 66 50
Offline KiwiJohn
« Reply #10 on: 19 Nov 2005 at 08:31 »
Daren, I have not taken it apart yet so dont really know what I need!  :lol:  However  the ratchet slips if I more than gently kick the pedal.
There seems to be two shafts associated with the starter, the pedal shaft and the ratchet shaft, if it is convenient for you to extract the ratchet shaft and all the bits on it that would surely get the piece(s) I need.  The book says the main ratchet wheel is only sold as a pair with the 11 tooth bevel pinion from the rear of the layshaft, so that one two please.
Part numbers
  11 tooth bevel pinion from layshaft   pn 27833  (plate 16 in my parts book)
  Ratchet shaft   pn 25991   (plate 18)
  plus these parts  (which are all on the Ratchet shaft)
                               25763
                                25771
                                36133
                                27832
                                SA.2818
                                 SA.2402
                                22409
                                16369
                                 25772
                               18114
                                19786
Of course if these bits are in good order that would be great but even if they are not I can hopefully get them reconditioned without having to have my bike laid up for months.
Any comments on what lengths you have to go to get these bits out would be gratefully accepted! :lol:
Thanks John
« Reply #11 on: 20 Nov 2005 at 08:58 »
Hi John
I have a gearbox that is missing the gear change cover and some of the final drive but the ratchet feels good do you want the whole box as you could rebuild it and add the missing bits when fitting to your bike? I think the postage would be around AU$100 to ship the whole thing but thats only a guess Regards Daren my mobile # in Aus is 61 413 02 66 50
Offline KiwiJohn
« Reply #12 on: 20 Nov 2005 at 22:15 »
Hi Daren
Sounds great,  whatever is most convenient for you.  Lets plan on sending the complete thing we can always review if the freight makes it prohibitive.
Please get an estimate on the freight and let me know what the total is you would be wanting for it.
My email is  xxxxxxxxxxxx  Please use personal message or email link at left.
thanks
John - for protection of your privacy I have removed your e-mail address from public view.
Alwyn
Global Mod.
« Last Edit: 21 Nov 2005 at 19:57 by Dave »
