Author Topic: wanted timing gear wheel  (Read 732 times)
Offline tck
    • old racer
« on: 02 Jul 2022 at 19:17 »
I have a 1926 350 EW without a pancake dynamo the gear that drives the magneto (the top gear of the timing gears) via a tapered centre  has lost some teeth.
 I am told that the centre of the gear is removable and same gear outer is used on the EW and other Cams  the gear may be marked L or R
I am looking for a suitable replacement
Offline Jim
Re: wanted timing gear wheel
« Reply #1 on: 04 Jul 2022 at 08:13 »
Hello, unless yours is different to mine the magneto gear is one piece, regards Jim
Offline Daren W Australia
« Reply #2 on: 04 Jul 2022 at 11:11 »
If you use the "search box" type in pancake there are around 55 results
this thread has lots of info www.douglasmotorcycles.net/index.php?topic=6562.msg24596#msg24596
Regards Daren
Offline tck
    • old racer
« Reply #3 on: 06 Jul 2022 at 07:57 »
Having read that I am confused (even more) about the centre or solid gear  here is a photo of my much worn gear
