Author Topic: Torsion bar T35, RH + LH  (Read 402 times)
« on: 17 Jun 2022 at 05:57 »
I have dismantled the torsionbar from the frame of a 80+. There was a lot of dirt on rust on it.
Now I have noticed in the spares list LH and lRH bar have a different number and are marked red or yellow for left and green for right.
Do someone know the difference of the RH and LH? I can recognize no paint anymore!
They are 5/8" in dia, so standard T35 bars?
Re: Torsion bar T35, RH + LH
« Reply #1 on: 01 Jul 2022 at 06:12 »
I still hope someone can give me an information, what is the difference of the right and the left  torsion bar in T35 frame.
« Reply #2 on: 01 Jul 2022 at 07:45 »
Hello Michael,
   The 5/8" dia torsion bars are the heavier type fitted to the 'Plus' machines (and available as an option on the Mark series).
  As far as I am aware, there is no physical difference between the LH and RH torsion bars. Evidently, the thinking was that on initial fitting, the bars would take a 'set' as they bedded in, so should always be fitted to that same side (hence the colour coding). Thinking that through logically - assuming the bars don't get overloaded, they should only take that 'set' on initial loading, then remain the same. If you dont know the handing of your torsion bars, I would suggest that it would be OK to mark them up as LH or RH, and fit them as such. Then, after about 250 miles, remove a pivot bolt from one of the rear links to see if both links are still aligned and both torsion bars are taking an equal load, then adjust as necessary.
« Reply #3 on: 01 Jul 2022 at 09:00 »
Hello Eddie,
thanks for your information and the advice to use the unidentifyed bars. I will do so.
Many thanks
