Author Topic: 1926 ew carbs  (Read 307 times)
Offline flea
1926 ew carbs
« on: 11 Jun 2022 at 02:13 »
 asking for a mate who has a 1926 ew 350 , he wants to swap to a amal or some else for his ew as the original carbs are fairly worn out , which carbs would be a good fit .. thanks
Re: 1926 ew carbs
« Reply #1 on: 11 Jun 2022 at 09:16 »
My preference would be to rebuild the original, but if he wants an AMAL the spec would be similar to the AMAL used on the 350 in 1930, below.
Offline flea
Re: 1926 ew carbs
« Reply #2 on: 11 Jun 2022 at 19:08 »
thanks cardan , if he wants to rebuild any idea on best place for the parts , cant see anything on the club page
Re: 1926 ew carbs
« Reply #3 on: 11 Jun 2022 at 23:00 »
There's a guy in Australia who builds new AMALs to spec - he does the swap meets but I don't know his name/business. These would be the slightly later "276" style. Not sure if he can do them as small as the 4/007.
Offline flea
Re: 1926 ew carbs
« Reply #4 on: 11 Jun 2022 at 23:10 »
tried looking up the 4/007 on the amal site but nothing there so mustnt stock parts for it anymore so might be the same trouble as the b and b carbs , have been given a lead on a bloke in qld by a member that i will have to check out
Re: 1926 ew carbs
« Reply #5 on: 12 Jun 2022 at 03:13 »
The "4" changed from bronze to alloy and became the "74", then later this became the "274". You might find a new 274, but I'd prefer the original B&B.
Offline flea
Re: 1926 ew carbs
« Reply #6 on: 12 Jun 2022 at 03:46 »
WOW .. now thats getting confusing , thanks that is going to help a lot , a lot of knowledge here and it really helps , thought the changes in my old xs650 model carbs were bad enough
