Author Topic: TS Cylinders ?  (Read 460 times)
Offline Marcus
TS Cylinders ?
« on: 24 Apr 2022 at 08:14 »
I was recently given a small box of engine parts for my 1925 TS. Amongst them were 2 cylinders, however these are not a pair, one has screwed connections on both the inlet and exhaust ports while the other has a flange connection on the inlet, the other obvious difference is that the one with the flange has more fins between the ports. The bores are both the same size.
Could someone please tell me what these cylinders are off.
Marcus
« Last Edit: 24 Apr 2022 at 09:13 by Marcus »
Offline GlennMckenzie
Re: TS Cylinders ?
« Reply #1 on: 28 Apr 2022 at 02:20 »
Veteran on the left, modified TS on the right.
Regards Glenn
Offline Marcus
Re: TS Cylinders ?
« Reply #2 on: 29 Apr 2022 at 21:17 »
Thanks Glenn for clarifying that, my luck as usual that the one that I could use has been modified. I will see if its possible to resurrect the intake port thread on the TS cylinder.
Marcus
Re: TS Cylinders ?
« Reply #3 on: 30 Apr 2022 at 04:11 »
Hi Marcus
Happy to trade a TS barrel for the veteran.
