Author Topic: D28 parts  (Read 729 times)
Offline JLO
D28 parts
« on: 21 Apr 2022 at 06:39 »
Hi all, I am restoring a D28 at the moment, A few parts I am missing are as follows,
1. Timing side cover, similar to 350EW but with a small square oil drip window
2. Inlet manifold.
3. Carburetor B&B horizontal mount or at least the correct bowl for this carby
4. D28 petrol tank, similar to ew but with no gearchange slot and no dripper slot.
If anyone has any of these parts or suggestion of anyone I could try would be appreciated.
Regards John
Offline Daren W Australia
Re: D28 parts
« Reply #1 on: 21 Apr 2022 at 07:43 »
Hi John
I have a EW 600 tank that has been flattened out to make a pattern if you want I can trace around the components on paper and send it to you ta Daren
Offline JLO
Re: D28 parts
« Reply #2 on: 21 Apr 2022 at 09:16 »
Hi Daren, thanks for your reply, I have 2 350ew tanks that I could modify however the 600 tank pattern could be a good option if after discussion with my tank repairer/painter he thinks its a better way to go. Thanks again John
