Hi Neil
I fitted a sealed bearing the last time the G/Box was striped, dont be perswaded to remove the inner seal these bearings are lubed for life ,new shims where made from standard brass shin stock i am sure you can still buy this stuff from a motor factors sometimes sold in a tin with differant thicknesses rolled up in the container ,assemble with standard sealant
hope this helps
Clive
