Author Topic: Dragonfly clutch thrust bearing oil seal  (Read 297 times)
Offline triton999
« on: 04 Apr 2022 at 12:28 »
Can anybody help me to source an oil seal for the clutch thrust bearing on my Fly?  I have tried all the obvious places and no-one has the seal which is stamped A960979A. This is believed to be a Chicago Rawhide seal number.  Better still, and even more unlikely, has anybody got one?
Re: Dragonfly clutch thrust bearing oil seal
« Reply #1 on: 04 Apr 2022 at 12:48 »
Try the LDMCC spares scheme - they used to stock them. Very few bearing stockists list them - they are an odd impreial O.D.. The 30mm bore is not a problem, but you may need to make a reducing sleeve for the clutch spigot if the LDMCC can't help with the genuine article.
Offline Red
« Reply #2 on: 05 Apr 2022 at 09:21 »
If the part you are after is part number 21962 - clutch spigot oil seal (plate 12 in the Dragonfly spares book) - then yes the club does have them in stock. If you are a club member then email the club's post war spares secretary.
Roy
