Author Topic: Magneto type  (Read 1444 times)
Offline saluki42
Magneto type
« on: 21 Mar 2022 at 10:09 »
Hi there, could anybody tell me what type of Lucas Magneto would have been fitted as standard to a 1934 Model Z, I would assume its the same as the  Z1 but may be wrong. The jigsaw puzzle I'm working on came with most of a Lucas MN2 but this doesn't seem to tally with the few photographs I've seen on other Model Zs.
Any information would be helpful.
Chris
Offline EW-Ron
Re: Magneto type
« Reply #1 on: 21 Mar 2022 at 20:47 »
This question was part answered for you before ?
https://www.douglasmotorcycles.net/index.php?topic=8181.0
Offline EW-Ron
Re: Magneto type
« Reply #2 on: 21 Mar 2022 at 21:12 »
Bonhams had this 34 Z1 with the magdyno more or less visible
https://images1.bonhams.com/image?src=Images/live/2013-03/20/8745273-2-14.jpg
Hopethishelps ?
Offline saluki42
Re: Magneto type
« Reply #3 on: 22 Mar 2022 at 14:31 »
Thanks a lot for that it helps a great deal as far as it rules out the MN2 magneto which has a much more angular profile. I should be able to narrow it down from there.
Chris
Offline EW-Ron
Re: Magneto type
« Reply #4 on: 22 Mar 2022 at 23:44 »
Is the spindle height of this MN2 in the ballpark.
If you don't require the generator piggybacked up top, it could work ?
Total loss electrics for daytime only riding is not impossible.
Offline saluki42
Re: Magneto type
« Reply #5 on: 23 Mar 2022 at 08:21 »
Luckily very close to the correct height and what with slight adjustments to the feet and the strange drive coupling they employed the alignment should be no problem. Also the MN is designed to have a piggy backed dynamo for power.
Chris
Offline EW-Ron
Re: Magneto type
« Reply #6 on: 23 Mar 2022 at 20:53 »
I'm wondering if you have the correct part, and the douglas pic above has a later magdyno installed ?
Without seeing what the parts list* specified - *if they exist ?
Offline saluki42
Re: Magneto type
« Reply #7 on: 28 Mar 2022 at 08:54 »
Hi again sorry about the delay in replying, no there doesn't seem to be a spec for any part of the Model Z / Wessex bikes. I have managed to track down a couple of photographs which show something of the mag dynamo, unfortunately from strange angles, and they seem to show what looks like either the MN2 or MOL model which I can only track down as a single cylinder version. I think I am going to have to stick to my MN magneto and keep looking for the correct Cam end cover to replace my damaged one.
Thanks for your help on this
Chris
Re: Magneto type
« Reply #8 on: 28 Mar 2022 at 09:23 »
Hi Chris,
I just saw a pre war MN2 at Ebay UK; unfortunatelya bit expensive, but comlpete?
Offline saluki42
Re: Magneto type
« Reply #9 on: 28 Mar 2022 at 13:09 »
Ouch yes it is a bit pricey. Luckily mine is all but complete with the only damaged piece I'm having difficulty replacing being the and piece which housed the ring cam and points assembly. I've been looking for quite some time now without success but you never mind the show and sales season will be kicking in soon so I may find what I need.
Chris
