90+ front forks lower cap
Started by veikko1, 03 Feb 2022 at 11:25
veikko1
Hello
I find from my "box" two pairs different height caps to my 90+ model front forks? What is right??
Regards veikko1
douglas1947
Hello Veikko,
have had a look to the 80+ fork, I´m working on:
same high than on a standard MK5 fork nut (low insert).
