Author Topic: B31 Cams  (Read 5211 times)
Offline Clive
B31 Cams
« on: 01 Oct 2005 at 03:50 »
Hi Everybody,
my 1930 b31 has stopped, the cam gear teeth have stripped on the ex cam and the inlet is about too can anybody help please?
Offline Alan
Re: B31 Cams
« Reply #1 on: 05 Oct 2005 at 03:31 »
Clive: I have almost finished restoring a B29, which also had very worn gears and would have I would imagine the same set-up as you need. I was  put onto a chap who keeps a stock of gears for old english lathes etc which are still widely used. The tooth profile was the same and I was able to get the diameters and teeth numbers I wanted..then just a case of getting the gears slimmed down and the middle modified to suit. The chap operates out of a lock-up about 1 hr North of Sydney Aus and I can try to find his name, but try for lathe type spare gears first.
Offline Clive
Re: B31 Cams
« Reply #2 on: 05 Oct 2005 at 21:38 »
Thanks Alan,
Will try and locate some of the gears you discribe , if no luck will get into print again
Clive
