Yesterday at 09:23:12
S6 Oil Leak
Started by Jonathan, 15 Jan 2022 at 06:51
Jonathan
Have almost finished restoring a 1930 S6 but have a lot of oil leaking from around the Magneto Drive during test ride.
I have used a greased felt washer with the locking ring pressing directly on it.
In the spare parts list is lists:  Washer under nut for magneto drive, and Rubber ring for magneto drive.
As I don't have these, can anyone help with a measurement/photo/sketch of how these all relate to each other.
Thanks in anticipation.
Jonathan H
Jonathan H.
