Author Topic: Clutch parts wanted  (Read 920 times)
Offline martin1
Clutch parts wanted
« on: 12 Dec 2021 at 14:22 »
Hello,
I am looking for following clutch parts ( see photos ). The chain sprocket has a pitch of 5/8".
A complete flywheel is also welcome. Many thanks for checking your shed ; - )
Merry Christmas and a Happy New Year from Austria !
Martin
[Images added to post. 12Dec21  -Doug, Admin]
« Last Edit: 12 Dec 2021 at 15:12 by Doug »
Offline Daren W Australia
Re: Clutch parts wanted
« Reply #1 on: 12 Dec 2021 at 19:39 »
Hi https://buyoldengineering.com.au/ has the sprockets new ta Daren
Offline A31ndrew
« Reply #2 on: 17 Dec 2021 at 13:48 »
Hi Martin, I have a spare clutch/flywheel assembly, which I think is from a 350 model c.1930. I suspect you need something larger, but it is 8.5" (216mm) diameter and has a 22 tooth sprocket of 1/2" pitch. If it might be of interest, I'll clean it up and take some better pictures!
Andrew
Offline martin1
« Reply #3 on: 17 Dec 2021 at 16:19 »
Hello Andrew,
the clutch internals are interesting for me. The flywheel backing plate has a diameter of 210mm.
Can you please send me photos by E-mail.
All the best
Martin
