For Douglas enthusiasts worldwide since 2004
Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
Login with username, password and session length
Home
Help
Search
Login
Register
Douglasmotorcycles.net
Advertising and Classifieds
Douglas Motorcycles and Parts Wanted - Private
Oil pump drive nut
« previous
next »
Print
Pages:
1
Author
Topic: Oil pump drive nut (Read 920 times)
Charlie18
Full Member
Oil pump drive nut
on:
24 Nov 2021 at 04:38 »
The progress of restoring a 1926 Douglas EW model is a long process as no doubt many before me have discovered. I am looking for the drive nut for the oil worm drive . This nut threads onto the timing end of the crank which is a 1/2 inch thread and 20 tpi. The nut on my motor was welded on and had to ground off for removal and hence its damaged If anyone has a spare available it would be appreciated or even had one made information on the steel would be useful. Attached are photos of the nut. Cheers Doug
[Attachments converted to linked images. 29Nov21 -Doug, Admin]
Last Edit: 29 Nov 2021 at 20:47 by Doug
Logged
Cliffy73
Full Member
Re: Oil pump drive nut
Reply #1 on:
14 Feb 2022 at 22:07 »
I have one if you still require it can you measure the depth of it as there are a few different ones. Cheers Chris
Logged
Charlie18
Full Member
Reply #2 on:
15 Feb 2022 at 09:13 »
Chris Thank you for your reply regarding the pump drive nut. I’ve now had one made to suit so now I can move onto rebuilding the motor . I appreciate your interest and offer thank you Doug
Logged
Print
Pages:
1
« previous
next »
Oil pump drive nut
