Author Topic: CW 1925  (Read 3925 times)
Offline Gary Severinsen
CW 1925
« on: 27 Sep 2005 at 08:16 »
Can anybody tell me what the oil drip speed should be on a 1925 CW ?
« Last Edit: 27 Sep 2005 at 10:38 by alwyn »
Re: CW 1925
« Reply #1 on: 27 Sep 2005 at 23:56 »
The manual for my TS (which has the same motor) says "In practice, therefore, one determines by experiment what opening of the valve is best suited to his engine".
It then goes on later to say "Generally speaking this valve should be opened only so far as will allow the pump to empty itself every eight or nine miles. This will suit moderate speed from 25 to 30 miles per hour. If higher speeds are indulged in, the valve should be set to allow the pump to empty oftener, say, every five miles"
In practice I use about a drip every 2 seconds
« Last Edit: 28 Sep 2005 at 02:21 by alwyn »
