Author Topic: Dragonfly Igntion Timing  (Read 874 times)
Offline umiq88
« on: 01 Nov 2021 at 08:13 »
Hi just refurbished a electrical system on a 56 dragonfly. Does anyone have a manual on how to set ignition timing?
Re: Dragonfly Igntion Timing
« Reply #1 on: 01 Nov 2021 at 09:08 »
The original reccomendation was to start with a static setting of 5 degrees BTDC, however that was for the fuel of the day, and with a new advance/retard unit. I would suggest you start at 5 degrees BTDC and then experiment until you find the 'sweet spot' where the engine runs the smoothest - the fully advanced setting being more important than the static one.
Offline umiq88
« Reply #2 on: 05 Nov 2021 at 13:27 »
Thanks Eddie, have you a manual or more detailed description how to set timing?
Are their static timing marks somewhere?
