Hi Chris,
Did the photo's I posred come out OK. I did a couple of rough drawings with dimensions. Bear in mind the items I measured may be a little worn and a few thou under the nominal size. You will probably build a Flywheel puller too, (If you haven't already) If there is any other details you need please let me know.
