Author Topic: 1930s Primary chain guard  (Read 962 times)
Offline saluki42
« on: 28 May 2021 at 10:06 »
Hi there has anybody got any information relating to the cast primary case fitted to the 1930s 600s. The one that cam with my project bike is in more parts than the rest of the bike so I'll either need to find a replacement or more likely if I can get some dimensions fabricate a new one myself
Offline alan reid
Re: 1930s Primary chain guard
« Reply #1 on: 28 May 2021 at 16:15 »
Hi There is a inner cast chainguard on ebay, look up onlinebikebits. It,s a T6 or S6 one 1930.
Good luck.
Regards Alan
Offline saluki42
« Reply #2 on: 28 May 2021 at 16:49 »
Thanks for the heads up Alan just had a look and couldn't find it but will have a better look later
Offline Daren W Australia
« Reply #3 on: 28 May 2021 at 20:40 »
Is it this one www.ebay.co.uk/itm/153690676606 ? ta Daren
Offline saluki42
« Reply #4 on: 28 May 2021 at 22:01 »
I think that is the one referred to Daren but unfortunately its not the sort I'm after. The chain case I'm after incorporates the clutch cable holder and adjuster entering from the lower front position and is held in place by the four crankcase bolts. I have one which I think was made by a previous owner but its irreparable I'm afraid. Think I'd better post some shots of it to clarify what i need.
Chris
