Dragonfly Points
Started by umiq88, 20 May 2021 at 16:00
umiq88
Hi just done an upgrade on a '56 Dragonfly. I've changed it to twin coil wasted spark and installed a Velleman kit fed by the points (had to change to neg earth for kit to work).
Everything is working fine except for the points. There is no continuity between the contacts when closed. If I bridge the points with screwdriver and remove then I get spark.
Are points available for this bike or are there any alternatives?
yosemite
The club spares scheme may have points.
Am I right in thinking that the velleman kit is one that only uses a small current through the points to trigger the electronic citrcuit to drive the coil? If so then the points should be reusable if the contacts are cleaned up unless there is another problem with them.
