Author Topic: Dragonfly petrol connecting pipe  (Read 826 times)
Offline Sgtbiro
« on: 13 May 2021 at 19:12 »
Hi All looking for a petrol connecting pipe and fittings for my Dragonfly .
Thanks Kevin..
Offline patrickwhitty
Re: Dragonfly petrol connecting pipe
« Reply #1 on: 14 May 2021 at 19:53 »
I bought the correct nuts and the pipe ends from Burton Bike Bits. I'll try making up a connecting pipe (version 2) on Sunday using 8mm copper pipe. I'll keep you informed. The pipe ends are ribbed to grip a rubber or plastic pipe but taking the ridges off on the lathe (or with a file) should make them a tight fit into the 8mm pipe.
Patrick
