Author Topic: clutch operating cam fixed part  (Read 680 times)
Offline saluki42
« on: 02 Apr 2021 at 11:17 »
Hi I'm looking for the fixed part of the flywheel cam, the part that locates over the crank case bearing boss and holds the three hardened steel rollers. If there is any body out there who can help me I would be very grateful.
Chris
Offline giz.neal
Re: clutch operating cam fixed part
« Reply #1 on: 03 Apr 2021 at 09:52 »
Chris,
Do you have part no's ?
Steve
Offline saluki42
« Reply #2 on: 03 Apr 2021 at 10:07 »
Hi Steve in the parts book it is called "Bearing with rollers and pivot pins" and the part number is given as C/11228. I've attached a couple of photographs from Doug of these and apparently the number of slots varies between 1 and 4, any will fit mine.
Chris
Images extracted from cam unit.docx - Dave, 05Apr2021
« Last Edit: 05 Apr 2021 at 00:34 by Dave »
Offline giz.neal
« Reply #3 on: 06 Apr 2021 at 16:04 »
Chris, had a quick rummage as I thought I might have something like this but I'm afraid not. Sorry bit can't help.
Steve.
