Author Topic: Whining noise  (Read 1027 times)
Offline Sgtbiro
Whining noise
« on: 28 Mar 2021 at 17:35 »
Hi I have just managed to get my Fly started but I am getting a very load screeching/whining noise which I think is coming from the gearbox sounds like something might be too tight in there.
Any ideas.
Cheers Kevin...
Re: Whining noise
« Reply #1 on: 28 Mar 2021 at 17:55 »
Kevin,
          Take the clutch inspection cover off the bellhousing and check that there is some free movement on the clutch release operating arm. If the arm is hard up against the inside of the bellhousing, you will need to adjust the arm ( there is a clamp bolt half way along the arm to facilitate this). If the arm is clear of the bellhousing but prevented from moving by the clutch cable, adjust the cable back to give about 3mm of movement. Without this movement, the release bearing will under permanent load and protest loudly. With the clutch properly adjusted, check whether the noise still persists, then try lifting the clutch while the engine is running - this will establish whether the noise is coming from the back of the engine or the gearbox.
Offline Sgtbiro
Re: Whining noise
« Reply #2 on: 29 Mar 2021 at 20:37 »
Hi Eddie thank you for you reply you know i always appreciate it, i will give your suggestion a go tomorrow night and let you know how i got on. by the way thank you for the info on sealing the induction pipes it seams to have done the trick, now i know what i have to do to sort the problem out.
Regards Kevin..
Offline Sgtbiro
Re: Whining noise
« Reply #3 on: 01 Apr 2021 at 18:40 »
Hi Eddie just to let you know lifting the clutch arm of the bell housing has done the trick engine sounds sweet as a nut now thank you.
Regards Kevin..
