Author Topic: Dragonfly Chain  (Read 534 times)
Offline Sgtbiro
Dragonfly Chain
« on: 22 Mar 2021 at 21:27 »
Hi all, could someone advise me to which is the best chain for a Dragonfly.
Cheers Kevin..
Offline patrickwhitty
Re: Dragonfly Chain
« Reply #1 on: 24 Mar 2021 at 08:16 »
I bought a chain from Burton Bike Bits, 5/8" x 1/4" x 94 links. It came with a connecting clip. I was going to fit it weeks ago but first it was too cold and horrible and since then I have found several other things that needed to be done. I'll be using the Dragonfly to go to work for the rest of this week but I will really get round to fitting it on Sunday. Promise. I'll tell you what I think of the chain once I've fitted it.
Re: Dragonfly Chain
« Reply #2 on: 29 Mar 2021 at 06:50 »
I fitted the Renold chain which went on easily enough, a lot easier than removing the old one. Fitted the sprockets, the length was right and it behaved well enough on a test run. It certainly looks more respectable than the old one. I think Renold chain would have been fitted originally so the Dragonfly should be happy with it.
Congratulations on getting your Dragonfly running, what was the problem? Good luck with the unhappy noises.
Offline Sgtbiro
Re: Dragonfly Chain
« Reply #3 on: 29 Mar 2021 at 20:31 »
Hi Patrick
Thank you for your reply's its much appreciated i will take a look at the chain you have put on your Fly can you please let me know where you bought it from.
After checking the timing again and resetting it, then trying a trick recommended to me by Eddie i put some silicone sealer around the induction pipes and low and behold it started.
I have also had an e-mail from Eddie regarding the noise coming from the gearbox which i will have a go tomorrow night.
Cheers Kevin
Re: Dragonfly Chain
« Reply #4 on: 30 Mar 2021 at 06:29 »
Good morning Kevin. The Dragonfly's chain came from Burtonbikebits.net. The part number was 110054, 5/8 x 1/4 and 94 links. They hide their chains under the heading of 'engine parts' and it is listed under 'single chains'.
Patrick
Offline My 4th bike
Re: Dragonfly Chain
« Reply #5 on: 31 Mar 2021 at 23:06 »
5/8 x 1/4 inch chain the Reynolds No. (Sgtbiro) 110054.
The Modern roller chain number is 520.
EK Chains 520 O-Ring 120L Chain.
« Last Edit: 31 Mar 2021 at 23:22 by My 4th bike »
