Author Topic: S6 sparking problem  (Read 2092 times)
Offline Martin foot
S6 sparking problem
« on: 03 Mar 2021 at 21:52 »
 My s6 mag has a spark out of the engine but no spark when fitted into engine! Any ideas?
Offline Hamwic
Re: S6 sparking problem
« Reply #1 on: 04 Mar 2021 at 09:19 »
Do you have a kill switch, and is it connected? It might be permanently on if the wire to it is trapped somewhere. presumably the mag is actually rotating, and timed to the right cylinder?
Keep us posted!
« Reply #2 on: 04 Mar 2021 at 10:38 »
Hi Martin,
                Have you got the correct rotation magneto? On the S/T6, the magneto turns in the opposite direction to the crankshaft. With the mag off the engine, you could be turning it in the wrong direction when you obtain a spark.
Offline Martin foot
« Reply #3 on: 04 Mar 2021 at 22:01 »
Hi Eddie
Yes I have the correct rotation and turn it the correct way when out of the engine!
Offline Martin foot
« Reply #4 on: 04 Mar 2021 at 22:03 »
Hi Doug
I do not have a kill switch but thanks for response
Offline EW-Ron
« Reply #5 on: 05 Mar 2021 at 03:20 »
Have you got a good electrical connection between maggie and engine ?
I've heard of someone who had much difficulty especially with starting,
and he discovered that the maggie was sort-of insulated from the engine.
A simple wire between the two improved things, muchly.
Is bolting the magneto down warping something, perhaps ?
Unlikely, but its a strange problem.
Offline yosemite
« Reply #6 on: 05 Mar 2021 at 11:27 »
can I ask how you are rotating the mag when off the bike? by hand or with something like an electric drill? if you are using an electric drill then the speed of rotation on the bike may be slower and not result in a spark.
Offline Martin foot
« Reply #7 on: 05 Mar 2021 at 23:20 »
Rotating mag by hand thanks
« Reply #8 on: 12 Mar 2021 at 05:54 »
I'm not sure if this is true for magnetos, but I have experienced ignition systems on Italian bikes (Moto Morini, electronic ignition) that will spark happily with the plugs out, but not spark under compression. Maybe the maggy needs some attention
