Hi All,
Aero valve lifter project update. AKA "Gearbox and Knee Saver"
I have made up some replacement valve chest covers that carry valve lifter components that when fitted seem to work. Because of the cylinder offset, and the proximity of the generator, the rear is more difficult to arrange than the front, but it has been done.
I was going to utilise some readily available Ariel parts, but because of the minimal available space, I was only able to use the lever. These turned out to be brass castings, and needed sleeving to fit my pivot shaft flats.
As the valve only needs to be just lifted off its seat when easing the engine over at starting, lots of travel is not necessary. However, a long lifter nose should prevent an unwanted "Over centre" event that would hold the valve open.
The pivot axis needs to be very close to the valve chest window edge at its base to get sufficient clearance from other things, such that the lifter cam will fit under the tappet head. On the rear the bearing is entirely inside the chest. On the front the bearing is mostly outside. Both levers can be lifted with comparatively little effort and the engine swings over a treat once the compression has been popped.
All the parts needing permanent joins are silver soldered. This was primarily done to avoid distortion and to keep the cover flat. The milled surface of the plate is poor, but will give a key for the paint!
I intend mounting a cable stop on each plate, and holding the external lever in the "Off" position with a volute spring. The cables will be paired at a 2 into 1 cable stop under the tank, and then off to a handlebar lever.
More later!
Cheers for now
