Author Topic: Mk 5 outer spring cup  (Read 426 times)
Offline dalgrae
« on: 09 Jan 2021 at 09:18 »
Hi I am after one off outer spring cup ref plate 20 item 39 part number 29551 for my mk5 ,it is the smaller of the two cupped washers that fit to the vertical suspension lever to the torsion housing fitting.
Regards. Colin
Offline dalgrae
Re: Mk 5 outer spring cup
« Reply #1 on: 10 Jan 2021 at 11:16 »
Hi again problem solved,I have made one,I turned up a suitable sized washer and then used the ball end of a ball pein hammer as a former.
 Colin
