Author Topic: M32 Footrest lugs  (Read 697 times)
Offline Hamwic
M32 Footrest lugs
« on: 25 Nov 2020 at 09:44 »
Hi all,
My frame is now back from the finishers, and very pretty it is too. Further to my last question re footrest mountings, it seems I have a slightly different arrangement to the ones detailed elsewhere on the forum. There are two holes each side within a vertical slot, and the actual footrest bar was though the lower one, the bar being somewhat bent. When I tapped it out, it brought a length of thin wall 1/2" bore tubing with it. This piece of tube was originally brazed within the lugs, but was latterly held in by dirt and rust.
Would the two vertical holes suggest a separate mounting for the footrests and brake lever perhaps, or just some kind of potential height adjustment?
Any ideas gratefully received!
Many thanks
