Author Topic: valve guide clearance 2 3/4 hp  (Read 1154 times)
Offline a1mick
« on: 03 Nov 2020 at 04:48 »
does anyone actually know the valve/guide clearance figures for a 2 3/4hp mtr, are the valve springs sold by the club any good? has anyone else had valve sticking issues, valves from club also, guides cast iron. i'm getting over reaming my guides bigger on the side of the road, any advice apreciated.
Offline EW-Ron
Re: valve guide clearance 2 3/4 hp
« Reply #1 on: 03 Nov 2020 at 06:04 »
What clearances are you presently at ?
You must eventually arrive at a happy medium !
Its pretty common to take old motors down and then marvel at the huge clearances they were running at.
But I know not where 2 3/4hp motors would/should be ...
Are your guides chilled cast iron, these give a modicum of self lubrication.
If they are not chilled, all bets are off ?
« Reply #2 on: 03 Nov 2020 at 08:00 »
Mick,
          When we were involved with postwar spares, we were re-stocking with valves suitable for use with the then new unleaded fuel. G & S Valves told us that if the valves in the new material were going to be used in cast iron guides (rather than bronze), they would need an extra treatment to prevent them 'picking up' in the guides. One of the options was to have the stems hard chromed.
   Hope this helps,
Offline Black Sheep
« Reply #3 on: 03 Nov 2020 at 15:21 »
"they would need an extra treatment to prevent them 'picking up' in the guides. One of the options was to have the stems hard chromed."
Must be missing something here, but does this not render the valves useless for the ordinary tinkerer using cast iron guides? And does the humble 2 3/4 need high spec lead free valves? They have been running for 100 years on original spec steels and of course the petrol in these days didn't have tetra ethyl lead added anyway.
« Reply #4 on: 03 Nov 2020 at 16:38 »
I mentioned the advice the valve manufacturers gave us because the repro valves that are available today are very unlikely to be of a similar spec to those produced pre WW1 - and may even be modified valves from a modern engine - hence the possibility of a mis-match of valve and guide materials!
Offline tck
    • old racer
« Reply #5 on: 03 Nov 2020 at 18:56 »
I have been told that k-line bronze guides can be used has anyone tried this?
one link http://www.sbintl.com/KLine.html
Offline a1mick
« Reply #6 on: 03 Nov 2020 at 19:10 »
thanks eddie,   getting my valve stems coated was where i was thinking of going, what u said its anoying because i keep the bronze for guides here to and normally use it but for doug i thought i'd use cast iron! and the ''experts'' on other brands r allways upping me for using bronze! but it definetly seems like the guide material and stem material don't like one another. i have had other new no oil engines stick a valve on that 1st run, but ive never had to re ream them and its only happened that 1st ride, but doug, i keep reaming, they keep sticking. and yes i think the k line sleeves is a option to, i know lots of racers use them now and thats the advice they give me. it seems the general opinion [though nobody seems to really know] on clearance is around .003'' - .004'', seems a lot, having said that, i dont want to admit the clearance i'm at now.
Offline Jonathan
« Reply #7 on: 03 Nov 2020 at 21:42 »
I have been using K-line bronze guides for many years.
Never had a valve stick.  The beauty is that when it is worn, a new guide can be put in with very little effort.
They run at .003” from memory.
Jonathan
Jonathan H.
