Author Topic: Mk dynamo  (Read 311 times)
Offline tck
    • old racer
Mk dynamo
« on: 17 Oct 2020 at 14:12 »
Not being blessed with a dynamo on my Mk4 project and noting the Douglas coyness in mentioning anything electrical or ancillary fitted to their machines, can I ask if the Lucas dynamo fitted as standard had a tapered shaft or a parallel one? What was the small gear that engaged with the magneto pinion, has it a Lucas part No? And ideas on where to find one.
Offline Hamwic
Re: Mk dynamo
« Reply #1 on: 20 Oct 2020 at 09:37 »
In the absence of any other replies, I think mine had the standard type dynamo as fitted to many Magdyno equipped machines of the 1950's. I think the dynamo drive gear is 22 teeth, the dynamo armature is parallel with a key to the drive gear. Copies of the Lucas equipment catalogues covering these is for sale on flea bay UK.
LUCAS-CLASSIC-MOTORCYCLE-EQUIPMENT-PARTS-CATALOGUE-FOR-MODELS-1958-62-LUC10-/263003350827
Re: Mk dynamo
« Reply #2 on: 20 Oct 2020 at 10:45 »
Yes, the dynamo drive gear is the same as used on most MO series Lucas single cylinder magdynos.
