Author Topic: Rear frame section  (Read 985 times)
Offline saluki42
Rear frame section
« on: 01 Oct 2020 at 13:31 »
Hi there does anybody happen to know the distance between the inside of the frame lugs where the gearbox fits on a 600.
Chris
Re: Rear frame section
« Reply #1 on: 01 Oct 2020 at 17:32 »
The tube centers are 3.5 inches; one inch tubes so 2.5 between tubes.
Offline saluki42
« Reply #2 on: 02 Oct 2020 at 07:30 »
Thanks for that Doug but what I'm really after is the separation between the centre cast lugs of the frame and the rear lugs of the gearbox section, the length of the exposed section of tubing. That section of my frame had been hammered flat and drilled to take a centre stand with a section subsequently hacked out for some reason so my frame builder is after a guide to assist with positioning and alignment of the replacement sections.
Chris
