Author Topic: Brake Plate springs  (Read 299 times)
Offline TonyC
Brake Plate springs
« on: 03 Sep 2020 at 15:43 »
Hi all,
Does anyone know if the club spares scheme can supply the 4 off springs that go between the brake plate and the brake band for the 20's and 30's machines.
I have just had a price from a spring specialist and they are a bit steep as it is a minimum order, so I don't mind waiting once the spares scheme is up and running again
Tony
Offline Red
Re: Brake Plate springs
« Reply #1 on: 03 Sep 2020 at 17:11 »
Hi Tony
I can't say what's in stock as I don't know, but if you look at page 3 of the current Conrod the pre war spares should be up and running by the beginning of next month so hopefully you can hold off until then.
All the best
Roy
Offline Red
« Reply #2 on: 04 Sep 2020 at 09:42 »
Hi Tony
I knew I had read it somewhere. On page 36 of the March/April 2017 Conrod Dick Bradley said - We have in stock for all pre-war machines every spring for valve, clutch, fork, saddle, kick-start and brake return. So hopefully if you hang until next month you will get what you need.
Roy
Offline TonyC
« Reply #3 on: 04 Sep 2020 at 09:58 »
Thanks Roy,
Will wait and see
Cheers Tony
