Author Topic: Another Douglas 1915  (Read 5754 times)
Offline Jaak
« on: 27 Aug 2005 at 20:32 »
hello,
I have also an douglas motorcycle,
end it has also on the alluminium crank case (flyweel side) casting the year "1915" and the name "douglas".
The number on the motor is 32575 , and the number on the frame is 32468 , and the number on the gearbox is 26900 .
Like the list here on this forum by " identifying douglas motorcycles " schould it be from the year 1917 ,,,,,????
It has no starter ,it has a two speed gearbox. it has no drumbrakes , it  has one chains
from the flyweel to the gear box and a belt  from the gear box to the rear wheel .
could some one give me any explanation ore more details to identify the right year of building...
( sorry for my bad englisch......)
greatings from Belgium,
Jaak
« Last Edit: 29 Aug 2005 at 00:27 by alwyn »
Offline alwyn
  • 1928 - 2009
  • Co-Founder
« Reply #1 on: 28 Aug 2005 at 04:07 »
...it has also on the alluminium crank case (flyweel side) casting the year "1915" and the name "douglas".
Jaak
Doug may like to comment on this question? - from my check of the tables, Jaak is correct in asking if the bike may be from 1917 and not 1915 per the crankcase casting - the frame and engine numbers are more within range of the 1917 2 3/4's but the gearbox number seems way off - maybe it's not the original gearbox?
Can you post a photo Jaak - see here for instructions about uploading or sending photos << https://www.douglasmotorcycles.net/index.php/topic,321.0.html >>
Alwyn
Global Mod
Offline Jaak
« Reply #2 on: 28 Aug 2005 at 20:59 »
hello Alwyn,
here 2 photo's from my Douglas,,,,,
BTW. :  I search a front mudguard, maybe somebody have a suggestion ?
greetings
Jaak
Larger view HERE
Larger view HERE
« Last Edit: 22 Sep 2005 at 11:50 by Dave »
Offline Jaak
Re: Another Douglas 1915
« Reply #3 on: 04 Sep 2005 at 21:16 »
hello everyone,
I had expected more comment, explanation or questions concerning my Douglas.....  :question:
Jaak
Offline KiwiJohn
« Reply #4 on: 04 Sep 2005 at 21:30 »
Hi Jaak
I am sorry I cannot give you more information but I suggest you also try the London Douglas Motor Cycle Club.   They have a web site and I recommend them for all the assistance you might require including information and spare parts.
