Author Topic: Cowley speedometer  (Read 956 times)
Offline yoshimasa negishi
Cowley speedometer
« on: 18 Jun 2020 at 08:51 »
Hello
I plan to start the restoration of my Douglas model D31 600cc from now on.
I want to wear a speedometer.
I got two special gearboxes.
The gearbox ratio is 28/10 and 29/10.
I think I need a Cowley speedometer.
Is there a meter that fits the 28/10 ratio?
Is there a shop that can repair the Cowley speedometer?
Is there a shop that can manufacture Cowley speedometer cables and lock nuts?
In Japan, there is very little information on pre-war British cars, which is a problem.
Offline isettaman
Re: Cowley speedometer
« Reply #1 on: 18 Jun 2020 at 10:36 »
Hi yoshimasa
They are actually Cowey speedometers, however
Are you a wealthy man?
Try this one...
https://www.ebay.co.uk/itm/VINTAGE-COWEY-60-MPH-COMPLETE-SPEEDOMETER-SET/333627916102?hash=item4dadc5ff46:g:4jQAAOSwcLNe6fQa
Offline arturro
« Reply #3 on: 18 Jun 2020 at 13:38 »
The internal body of the early thirties Cowley speedometers are die-cast zinc. They are very prone to warpage and decay, making working Cowleys rare and expensive; and repairs not practical.
« Reply #4 on: 18 Jun 2020 at 16:39 »
Hi
From playing about with Cowey speedos in the past I can offer the following advice. Firstly, the nut at the bottom of the drive cable to screw onto the special Douglas front  hub gearbox (Illustrated above) were made at one time and were available from the LDMCC Spares scheme as were the gearboxes themselves. On Cowey models I have used, the thread on the back of the speedo head is the same or near enough the same to that used on domestic shower hoses and the shower hose itself makes an ideal "outer" for the drive cable. So a length of inner can be adapted to make the drive. It is probably quite a rare item nowadays but there was a small tool available to create a square on the end of the inner using a vice to crush it. To finish the drive cable to look authentic, the chrome plated spiral of the hose shower outer can be covered with thin leather carefully stitched up the side.
The Speedo head itself, again in the examples I have seen, is actually a very simple mechanism. I remember when I came into contact with my first one I spent a while consulting with all the speedo experts and could find no one willing to even look at it. When I took it apart I found that unlike Smiths chronometric and some of the other expensive and sophisticated speedos the Cowey was a simple centrifugal device which with care I was able to clean and repair.
Chris.
« Reply #5 on: 19 Jun 2020 at 15:20 »
Hello
Thank you for the great information.
I would like to try to repair the Cowley speedometer by myself, referring to Chris's advice.
I'm good at repairing cameras in the 1930s so I might be able to take advantage of that experience.
I'm looking for a shop that can make speedometer cables.
Offline roger h
« Reply #6 on: 19 Jun 2020 at 15:54 »
Hi Yoshimasa,
I've used Speedy Cables for car and motorbike speedo drive cables.
Best of luck,
Roger
« Reply #7 on: 09 Jul 2020 at 10:08 »
Hello
I bought a cowey speedometer complete set.
When I tested the speedometer, the hands, odometer, and trip meter were working fine.
I think that deteriorated oil stains have accumulated inside.
I would like to overhaul, but the screwed bezel cannot be opened.
Anyone have a good idea to open the bezel?
« Reply #8 on: 09 Jul 2020 at 11:46 »
With the control knob removed, try wrapping a car fanbelt around the rim and then trap the fanbelt in the jaws of a vice. With the rim held by the fanbelt, try to turn the main casing.
« Reply #9 on: 09 Jul 2020 at 11:55 »
Hello Eddie
thank you for the advice
I'll try using a rubber bell trench.
Thank you
Yoshimasa
« Reply #10 on: 10 Jul 2020 at 14:17 »
Hello
Thanks to Eddie's advice, I was able to safely remove the bezel.
We will disassemble and clean the inside.
Thanks for the precise advice.
