Author Topic: Mark 5 petrol taps  (Read 647 times)
Offline rabbit909
Mark 5 petrol taps
« on: 30 May 2020 at 19:09 »
Hello
I am looking to replace the original taps on my mark v
Any recommendations? I am not sure what the tank thread is.
Canít seem to stop the off drip when closed. Changed to rubber kit from cork.
So thought see if a good replacement at a reasonable price.
Thank you in advance
Re: Mark 5 petrol taps
« Reply #1 on: 31 May 2020 at 07:51 »
The tank thread is 1/4BSP (British Standard Pipe thread).
If you are having problems with re-corked taps still leaking, check out the corks carefully - some are made from poor quality cork, and others have the hole off centre.
Offline EW-Ron
« Reply #2 on: 31 May 2020 at 09:40 »
Boiling up the corks for a while will often improve them,
if they are not actually broken or crumbling.
Offline Neville Heath
« Reply #3 on: 31 May 2020 at 10:35 »
Make some. Snag is you need to make a whisky cork available!
Neville
Attachments converted to linked images - Dave, 07Feb2021
« Last Edit: 07 Feb 2021 at 07:17 by Dave »
Offline rabbit909
« Reply #4 on: 31 May 2020 at 12:26 »
Thank you very helpful as usual
Offline Pallijen15
« Reply #5 on: 09 Jun 2020 at 10:36 »
Hi Doug, I had problems with new taps I fitted to my MkV. The lever type where the lever travels from horizontal to vertical, quarter of a turn. If you are using this type of tap and it has a locknut to lock tap in position when fitted PTFE tape must be used as it leaks down the thread.
Offline Daren W Australia
« Reply #6 on: 09 Jun 2020 at 22:08 »
