Author Topic: Spell Checker doesn't appear  (Read 8827 times)
Offline Dave
« on: 26 Aug 2005 at 04:51 »
The Spell Checker uses a popup window. If you have any sort of popup blocker software running on your PC, or have enabled popup blocking in your browser, you may need to adjust the settings or turn it off.
« Last Edit: 27 Aug 2005 at 01:05 by Dave »
Re: Spell Checker doesn't appear
« Reply #1 on: 27 Aug 2005 at 01:02 »
My pop-up blocker blocks the spell check window, then the spell checker loads in the main session window.  If I disable the pop-up blocker (Pop-Up Stopper Free Edition), the spell checker works in the pop-up window.  Either way it spell checks, preview, and posts fine.
Offline Dave
« Reply #2 on: 23 Oct 2005 at 07:30 »
I'm afraid the Spell Checker has stopped working following the move to the new server. It requires a special module which isn't currently installed. I've asked the hosting company if they can install it,  but they seem to have had difficulty with it in the past. So I'm not sure they will be able to do it - we may be without a spell checker for a while.
« Last Edit: 24 Oct 2005 at 05:02 by Dave »
