Author Topic: EW 1926  (Read 2152 times)
Offline PhilEW
EW 1926
« on: 13 Apr 2020 at 06:31 »
Hello,
I am french and i recently bought this 1926 EW. It has been restored some years ago keeping its original patina when possible and is running. I only started it, but did not ride it since.
I am only the third owner since 1926. It is not completely original, but keeps traces of its former life. I find it very beautiful as well, that's what made me want to buy it.
« Last Edit: 13 Apr 2020 at 07:06 by PhilEW »
Offline arturro
Re: EW 1926
« Reply #1 on: 14 May 2020 at 11:48 »
Dear PhilEW
Can you add photos of your Triumph?
Offline arturro
Re: EW 1926
« Reply #2 on: 14 May 2020 at 11:48 »
Sorry  Douglas EW  :D
Offline Eric S
Re: EW 1926
« Reply #3 on: 14 May 2020 at 14:35 »
Welcome on the forum.  I am from Lyon or nearby.
I hope your bike work and you don't find any trouble. The one I got was also supposed to be trouble free and I am neck dip in problems since I had it...
Slowly emerging, hopefully!?
Offline PhilEW
Re: EW 1926
« Reply #4 on: 17 May 2020 at 15:54 »
Sorry, I did not see your replies.
The bike works, but I need to get used to it, I've never used such an old bike.
This morning, I drove a little, the engine works well, but it was difficult to use the gearbox well.
She also smokes a lot.
I make additionnal pictures as soon as possible.
Offline PhilEW
Re: EW 1926
« Reply #5 on: 17 May 2020 at 16:42 »
3 additional pictures of the Triumph Douglas
[/URL]
Offline Eric S
Re: EW 1926
« Reply #6 on: 17 May 2020 at 17:34 »
What do you mean about the gear box?
Offline PhilEW
Re: EW 1926
« Reply #7 on: 18 May 2020 at 06:04 »
The first gear is engaging well, but for 2 and 3, it is difficult, with false neutrals.
Re: EW 1926
« Reply #8 on: 20 May 2020 at 00:49 »
Check for slop in the pivot points in the gear linkage, it sounds like the rod is not moving the gear mechanism enough to engage the higher gears properly
Offline PhilEW
Re: EW 1926
« Reply #9 on: 14 Sep 2020 at 19:46 »
Now it goes well, with no more problem with the gears after setting the gear linkage. I also needed to get used to this bike.
You can see the bike running here:
https://www.youtube.com/watch?v=RRhgZwU8FbE&feature=youtu.be
« Last Edit: 15 Sep 2020 at 06:05 by PhilEW »
Offline arturro
Re: EW 1926
« Reply #10 on: 15 Sep 2020 at 06:56 »
Dear PhilEW.
Nice sound . Great job :)
Good luck.
Artur
