The EIC A2 magneto for the RA is a bit unusual: it is anti-clockwise rotation (viewed from the drive end) and it mounts with a clamp over the top. A similar version was used on the S1/S2 and OB, albeit with different mounting.
There is a more common version of the A2 that went on 2 3/4 models in the mid 1920s: it is CW rotation, and has a base plate with "wings" and two holes for mounting.
I have built up an A2 for my RA/TW, but I have a couple of issues:
(a) Did the original EIC A2 magnetos for OHV Douglases use the small "M" taper (where the drive gear is held in place by a screw into the armature), or the larger "K" taper? All the A2s I've seen have the small taper, but the magneto drive gear in the RA is bored for a K taper.
(b) What sort of base plate was used when the magneto was clamped to the top of the motor? I have fitted a plain base plate - with no wings - but there is a bit of movement fore-and-aft movement between the mounts. This wouldn't effect the meshing of the gears, but should the magneto fir snugly between the mounts?
Any help appreciated.
