t6
Started by derek morgan, 22 Feb 2020 at 15:38
derek morgan
good afternoon all,would be very grateful for advice on my t6. am looking to taking inspection covers off heads to look at valves etc could anyone advise on how to separate, have tried very gently with wedge but they may have never been off before, and it looks as if I may have to take kick start off to remove a bolt, is this straightforward, many thanks derek morgan
EW-Ron
Bumping things gently from several directions with a rubber mallet is likely less damaging than that 'wedge",
but note I don't know the T6 - there is only the one retaining bolt ?
Old type gasket material, can't recall the names is somehat like a very strong glue in some cases,
so it might take quite a bump or 6...
Derek,
Or try kicking it over on compression. Leave a few bolts in so the cylinder head does not go flying.
I cannot figure out why the kick starter would be in the way of removing the cylinder head bolts.
Or are you talking about the tappet chest covers? Still, do not see how the kick starter comes into play.
derek morgan
many thanks ron and doug for your time,have taken the tappet covers off and all seems fine there. there are about 6 bolts holding cylinder heads of which 5 come out ok but one of the bottom ones will not come out as they are quite long and kick start is in way,this is the back cylinder have not tried the front one yet.all the best derek
