Author Topic: B29 Oil Change  (Read 633 times)
Offline cycarmark
B29 Oil Change
« on: 29 Jan 2020 at 21:33 »
I changed the oil in the B29 today.  I had to remove the entire oil pump to drain the oil sump.  Is this the correct procedure or is there a drain plug somewhere else that I must have missed?
Offline douglas1947
Re: B29 Oil Change
« Reply #1 on: 30 Jan 2020 at 05:38 »
This is the right way.
Offline cycarmark
Re: B29 Oil Change
« Reply #2 on: 01 Feb 2020 at 22:04 »
Thank you Michael, I guess the oil change is also a good time to clean the oil pump screen too.
Offline cycarmark
Re: B29 Oil Change
« Reply #3 on: 19 Feb 2020 at 14:37 »
One other question, does the oil pump have a red fiber washer that seals it to the bottom of the oil sump?
Offline douglas1947
Re: B29 Oil Change
« Reply #4 on: 09 Mar 2020 at 17:48 »
yes, on my engine is a washer between pump and oil sump.
Offline cycarmark
Re: B29 Oil Change
« Reply #5 on: 09 Mar 2020 at 21:10 »
Thanks Michael, I will add it to my list of parts for the LDMCC.  I did get it sealed with the old washer after I cleaned up the sealing surfaces on the washer.
Offline douglas1947
Re: B29 Oil Change
« Reply #6 on: 10 Mar 2020 at 17:13 »
I think the old washer will do, if the surfaces are still good.
I use straight  W50 oil for the engine.
Offline cycarmark
Re: B29 Oil Change
« Reply #7 on: 12 Mar 2020 at 13:00 »
As will I since I live in Florida!
